Scottie01
Feb 05, 2021Guide
Are Nighthawk X6s AC2200 Mesh Extenders truly Mesh Extenders?
I am using a Nighthawk X6 AC4000 (R8000P) router together with 2 Nighthawk X6S AC2200 Extenders (EX7700) in my home. The router is situated on the 1st Floor on a desk and the Extenders downstairs, 1...
- Feb 05, 2021
I've never tried it with using the wps button. I usually use the installation assistant.
The people who tend to have issues with daisy chain usually have the extenders to close to each other/the router.
Scottie01
Feb 05, 2021Guide
Thanks for your answer, which I understand. I think I have them in the star pattern rather than the daisy chain.
If I wanted to try the daisy chain, how would I set that up? Could I do it by pressing the WPS button on each of the Extenders?
Feb 05, 2021Guru - Experienced User
- Scottie01Feb 05, 2021Guide
Thanks. I'll try and keep mine as far apart as possible.
