wash's avatar
wash
Arlo enable button R7000 router
Recently my Arlo base station have been found to be defective and I was issued an RMA to return the unit.  In the meantime I have been trying to sync my Arlo wireless cameras to my Netgear R7000 router with no success.
First of all I can't find the Arlo enable/disable button in Netgear Genie or http://www.routerlogin.net.   One thing I did notice however is when I check the device connect list in Netgear Genie, I do see the cameras connected under the R7000 router, but the cameras do not show up on any of the Arlo apps.  Can someone help?
  • Retired_Member's avatar
    Retired_Member
    Aug 19, 2016
    Current r7000 FW does'nt support Arlo anymore.
    Retired_Member
