Wolfi1952
Sep 29, 2021Guide
Armor + Bitdefender on PC
I have installed Armor on my ORBI and all my PCs are protected using the Bitdefender Internet Security. Now Armor tells me that I should install Bitdefender Internet Security on my PCs, trying that ...
Sep 29, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
- Wolfi1952Sep 29, 2021Guide
Thank you,
I will give it a try.
- FURRYe38Sep 29, 2021Guru - Experienced User
đ
For any Orbi 50 series issues or information, please visit and post over in the Orbi AC forum:
https://community.netgear.com/t5/Orbi/bd-p/Orbi
Thank you.
