Majuro
Jan 17, 2022Tutor
Armor Security
I have RAX 20 Wifi router. It is said security has expired. Do I have to update Armor with additional fee? Thank you
Jan 17, 2022Guru - Experienced User
Netgear has set up a community forum specifically for the Armor product. Most of the people who watch that forum are more likely to have experience with Armor. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/NETGEAR-Armor/bd-p/en-home-armor
https://www.netgear.com/landings/armor
Good Luck.
- MajuroJan 17, 2022TutorThank you
