Asemah
Feb 24, 2018Aspirant
asemahsamad@hotmail.com
Hello i am writing for some help please My Netgear routerlogin online page keeps saying that my login info will be sent unencrypted so it’s not even sending my login info privately with encry...
- Feb 24, 2018
Only time you need a secure connection is if your accessing the routers web page from a remote location on the WAN side. HTTPS should be used and should work well. When your at home, HTTP is ok to use and nothing to worry about. If your the only one managing the router, then your fine.
Browsers are just making you aware of the possible problem. They will do that if your accessing a site even on the WAN side to make you aware of possible issues. Like if you access a bank site, should always be HTTPS. Bank will not allot HTTP for example.
Your fine.
Asemah
Ok thank you. I noticed the login always says user login will not be encrypted and similar message when I tried to set up plex was a bit worried.
So everything is ok I don’t need to change any settings?
Thank you
Thank you
Feb 24, 2018Guru - Experienced User
Your fine.
