slam142005
Jun 09, 2021Aspirant
ATT U-verse VIP 2500 wireless TV Receiver is freezing and losing the picture after 60 seconds .
my firestick is working in my upstairs room from my AX8 router but my ATT U-verse VIP 2500 is not working properly. i will have a picture and then the screen freezes .the a message keeps telling me t...
antinode
Jun 09, 2021Guru
> [...] I am still using the BGW210-700 modem from ATT U- verse.
As what? Modem or modem+router? Cascading multiple routers can
cause multiple problems. If the router in the BGW210-700 is (still)
active, then you might want to configure the RAX80 as a wireless access
point, rather than as a full-function router.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Set up the router as a WiFi access point".
Or, if it's possible, disable the router in the BGW210-700, and
connect all your devices to the RAX80.
Either way, one router, not more.
slam142005
BGW210-700 is a modem + router and Arris VAP 2500 connected to the modem + router . With a WPS button on the front of it. When I connected it up and then i went to the router login address it took me to the netgear nighthawk no the Netgear genie.
