togatoga
May 22, 2018Guide
"Attached devices" and "Access Control" not working on Nighthawk X10
Hoping someone can help before I give up and send this router back. Router setup was routine. I do not protect my home network with a password; rather I use a MAC access list, which worked with my ...
- Aug 07, 2018
ChristineT DarrenM I was able to change names and status from allowed to block and remove (null) devices.
Some of the devices had proper description as long as they were offine, as soon as they were connected to router the name was replaced with "n/a". In some cases I was able to fix the name in Access Control. In couple cases the name change was not being saved. In those cases I've used Connected Devices and the name was accepted.
Also changing device type in Connected Devices works. The Genie App still doesn't recognize the proper types of some devices. For example my iPhone type is set to iPhone and in Genie App is shown as Arlo.
That's it basically, both Access Control and Connected Devices are accessible again and working as intendet. Thanks.
ChibiKev
Jun 11, 2018Tutor
I have the same problem, where nothing shows up when clicking attached devices.
I also tried the many different firmwares but nothing seems to change :/
Smuttyfox
Jun 12, 2018Aspirant
I returned mine to place of purchase, as Netgear do not offer any support after the first 30 days.
My solution is to use a cheap modem/router (supplied by ISP), and install a wifi access point. I only bought the Netgear device as I live in a large home and wanted to get better wifi coverage than the ISP supplied device offered
