togatoga
May 22, 2018Guide
"Attached devices" and "Access Control" not working on Nighthawk X10
Hoping someone can help before I give up and send this router back. Router setup was routine. I do not protect my home network with a password; rather I use a MAC access list, which worked with my ...
- Aug 07, 2018
ChristineT DarrenM I was able to change names and status from allowed to block and remove (null) devices.
Some of the devices had proper description as long as they were offine, as soon as they were connected to router the name was replaced with "n/a". In some cases I was able to fix the name in Access Control. In couple cases the name change was not being saved. In those cases I've used Connected Devices and the name was accepted.
Also changing device type in Connected Devices works. The Genie App still doesn't recognize the proper types of some devices. For example my iPhone type is set to iPhone and in Genie App is shown as Arlo.
That's it basically, both Access Control and Connected Devices are accessible again and working as intendet. Thanks.
Biggz
Aug 08, 2018Initiate
Same issue...
Can someone point me in the right direction towards solving this issue. Please and Thank you!
bbaraniec
Aug 08, 2018Luminary
Biggz This firmware worked out for me: https://1drv.ms/u/s!AthXuzV6pOxpibRyy6-Z7PMXEoujVw
- bbaraniecAug 10, 2018Luminary
Question to moderators. Who and why removed my last post? This and previous post have same number...
- schumakuAug 12, 2018Guru - Experienced User
wireframeX wrote:
I am going back 36 to see if it works ....
This is a data corruption issue - nothing that happens just on the current firmware - appearing randomly.
- markpower77Aug 28, 2018Aspirant
Its unacceptable for Netgear! Ive had a D8500 from December 2017 and still no access. Have to keep resetting the router which is not an ideal situation for a £300 router. Not happy
- bbaraniecAug 30, 2018Luminary
Lurking here two weeks later, still nothing from Netgear. This is support at its finest.
- redeliamSep 08, 2018Aspirant
ChristineT I am having the same issues as bbaraniec . I cannot see any devices on the Attached Devices page. I also cannot see anything on the Access Control Page. Any Update on when a true fix may be released?
- ChristineTSep 10, 2018NETGEAR Employee Retired
Good morning redeliam,
I have asked DarrenM to work with you to get you the beta firmware for the R9000 that should resolve this issue. Please let us know if you are still experiencing this issue after you have installed the firmware so we can investigate further if needed.
Good morning to you too bbaraniec,
I'd like to take an opportunity to ensure we are both on the same page with regards to the issue(s) you are currently experiencing. I believe the beta firmware resolved the issue with Attached Devices, however, may have introduced a different issue with Ethernet ports locking up. Is that right?
We have created a new thread to track this issue separately under the following topic: R9000 Ethernet ports locked up on Beta firmware. This has already been escalated to engineering when it was first reported. Please allow me a chance to obtain an update for you.
Warm Regards,
Christine
- redeliamSep 11, 2018Aspirant
ChristineT thanks for the quick response to my inquiry. Unfortunately, the BETA did not resolve my Attached Device Issue. I also cannot see any devices on the Access Control Page. However, I can see a device count on the Basic Overview page. I sent some feedback back to DarrenM along with screenshots.
Appreciate the support.
cheers, redeliam
