mcsb's avatar
mcsb
Follower
Jul 05, 2021
Attached Devices in basic setup
How can I determine what the device is as the reference to it is unknown?
Many thanks,
1 Reply
  • > How can I determine what the device is as the reference to it is
    > unknown?
       "reference"?  Thanks to your detailed report, it's certainly unknown
    to me.  Wired or wireless?  Radio band?
       These days, a MAC address typically identifies a chip, which is
    typically sold to multiple gizmo makers, so it might be unrealistic to
    expect to identify a whole device based on a MAC address.  But there
    exist web sites where you can take yours (or the top half of it,
    anyway), and see what you can learn.  For example:
          https://dnschecker.org/mac-lookup.php
       If I were trying to identify some mysterious device which appeared in
    an Attached Devices report, then I might try some basic detective work,
    like, say, pointing a web browser at its IP address, to see if it
    responds with some useful information.
       Failing there, I might try powering on/off every "smart"
    Internet-of-Junk device which I could find (or, if desperate, section of
    the house), to see what comes and goes.
