dunehuang
Jul 08, 2019Tutor
Attached Devices is not showing
I am currently using R8000P with firmware version V1.4.1.42_1.3.4. The Attached Devices is not showing any devices that are connected. I am able to use NightHawk App to view the attached devices, but...
- Jul 24, 2019
I rolled the firmware back to v1.4.1.30 and my attached devices are back!
IrvSp
Jul 08, 2019Master
Usual answer is CLEAR THE CACHE on the browsers. May help, but that list has problems on many routers. A new Browser like Firefox might work for you even.
dunehuang
Jul 09, 2019Tutor
Thanks, I did all that, it still not working. If is happen to many devices, I think Netgear should fix the issue. In addition, Netgear is one of the best brands and it's products are not cheap. I hope Netgear will view the comment on this official community and act upon it.
