dunehuang
Jul 08, 2019Tutor
Attached Devices is not showing
I am currently using R8000P with firmware version V1.4.1.42_1.3.4. The Attached Devices is not showing any devices that are connected. I am able to use NightHawk App to view the attached devices, but...
- Jul 24, 2019
I rolled the firmware back to v1.4.1.30 and my attached devices are back!
JoseAndres041
Jul 18, 2019Luminary
I have an R8000P and could not reproduce this one. I have tried Chrome and IE. I have enabled/disabled QoS and my Attached Devices page still shows my connected clients. My suggestion is to factory reset your router or re-flash the firmware.
- Wired1Jul 23, 2019Tutor
I have the exact same problem after updating toV1.4.1.42_1.3.4. This router wasn't cheap even though it's been out for quite a while and the QoS worked great with VOIP right out of the box. I hope they fix this quickly. Is there a way to roll back to an earlier firmware?
- IrvSpJul 23, 2019Master
Wired1 wrote:Is there a way to roll back to an earlier firmware?
Yes, go to support, enter router model in the search bar, then select DOWNLOADS, open up PRIOR VERSIONS at the bottom of the list. Get the F/W and README. Follow instructions in README.
- Wired1Jul 24, 2019Tutor
