dunehuang
Jul 08, 2019Tutor
Attached Devices is not showing
I am currently using R8000P with firmware version V1.4.1.42_1.3.4. The Attached Devices is not showing any devices that are connected. I am able to use NightHawk App to view the attached devices, but...
- Jul 24, 2019
I rolled the firmware back to v1.4.1.30 and my attached devices are back!
JoseAndres041
Jul 18, 2019Luminary
I have an R8000P and could not reproduce this one. I have tried Chrome and IE. I have enabled/disabled QoS and my Attached Devices page still shows my connected clients. My suggestion is to factory reset your router or re-flash the firmware.
Wired1
Jul 23, 2019Tutor
I have the exact same problem after updating toV1.4.1.42_1.3.4. This router wasn't cheap even though it's been out for quite a while and the QoS worked great with VOIP right out of the box. I hope they fix this quickly. Is there a way to roll back to an earlier firmware?
