dunehuang
Jul 08, 2019Tutor
Attached Devices is not showing
I am currently using R8000P with firmware version V1.4.1.42_1.3.4. The Attached Devices is not showing any devices that are connected. I am able to use NightHawk App to view the attached devices, but...
- Jul 24, 2019
I rolled the firmware back to v1.4.1.30 and my attached devices are back!
IrvSp
Jul 23, 2019Master
Wired1 wrote:Is there a way to roll back to an earlier firmware?
Yes, go to support, enter router model in the search bar, then select DOWNLOADS, open up PRIOR VERSIONS at the bottom of the list. Get the F/W and README. Follow instructions in README.
Wired1
Jul 24, 2019Tutor
- myerswJul 24, 2019Master
Wired1 wrote:I rolled the firmware back to v1.4.1.30 and my attached devices are back!
That seems to be the common fix for issues right now. With the garbage firmware that Netgear is putting out, seemingly with out any testing, it seems that your experience is the norm.
- MalibuGuyAug 19, 2019Initiate
Agreed, firmware seems to get worse and worse. They probably put their unskilled programmers on the task of updates, with no QC oversight. Maybe Netgear's attitude is, "we got your money, now you mean nothing to us".
