MissMyBike
Apr 22, 2023Guide
Attached devices missing & rollback/reset advice
My R7000P with most updated firmware V1.3.3.142_10.1.75 is not showing any of the Wifi attached devices. Most online advice points to rollback of firmware or factory resets, with very inconsistent o...
- Apr 23, 2023
MissMyBike wrote:
Thanks for the tips. I reset the router. It found several more of the Attached Devices, but still an iPhone & an iPad that were connected did not show. Also, I noticed the MAC address for a number of the devices did not match the Wireless Address shown in the devices.
Newer iOS devices have a randomize MAC address feature that Apple considers a security measure. It causes havoc with Attached Devices lists. Recently the Android operating system on newer Samsung devices also incorporate a randomize MAC address feature. https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Apr 23, 2023Guru - Experienced User
Usually their first thing they recommend is a factory reset. Its why you see it so many times.
Sometimes old settings cause issues and a reset clears it out.
Did you try it?
Kitsap
Apr 23, 2023Master
plemans wrote:Usually their first thing they recommend is a factory reset. Its why you see it so many times.
Did you try it?
In a nutshell that is why you do not want to import an old configuration file. After the default reset, configure you router settings from scratch. Use screen snips if you have a complex configuration.
- MissMyBikeApr 23, 2023Guide
- KitsapApr 23, 2023Master
- michaelkenwardApr 24, 2023Guru - Experienced User
Kitsap wrote:
Recently the Android operating system on newer Samsung devices also incorporate a randomize MAC address feature.You can even do this in recent versions of Windows!
Use random hardware addresses in Windows 11 - Search
Grrrr.
