mzagorski1116
Jan 30, 2022Aspirant
Attached Devices
Hi, I just installed the Nighthawk R7000. I set up two SSIDs with passwords. When I go into the attached devices, I see a whole bunch that I do not recognize. It has a thrmostat, I don't have a wi...
mzagorski1116
Jan 31, 2022Aspirant
Not sure about the username, maybe my account was too new for it to show up.
Yes, this router was my daughters that she had a college, it appears to be slightly better than my old one so I decided to use it. The first thing I did was to a factory reset. Every time I try to update the FW it fails, so I'm not sure what to do about that. I know in my old router I could do a manual update so I'll see if I can find the same thing.
Thanks!
Jan 31, 2022Guru - Experienced User
Try setting up the router after a factory reset and see how it works. You may want to hold off of FW updates for now.
