IVDan's avatar
IVDan
Attaching Router to Gateway
I have been using a 5G Mobile Broadband gateway (modem + wifi router) for the past several months but was having some issues with the gateway allowing some devices to connect.
So just today I turned off the wifi on the gateway and attached my Nighthawk wifi router instead.  So far everything is working great - all devices are connecting.
My questions is --- should I activate the IP PASSTHROUGH mode available on the gateway?  I am seeing in the Nighthawk Logs repeated DOS attacks being recorded with the IP address of the gateway - I am presuming these are not really attacks.
Anyway just looking for advice on how to optimize my set up.
Thank you!
  • plemans's avatar
    that'll fix the double nat.
    But if its working as it should and giving good speeds, why fix what isn't broken.
    • IVDan's avatar
      IVDan
      Good point about don't fix what isn't broken! Thank you.
