punsk
Oct 24, 2016Aspirant
Avast Mac Security reports vulnerability on my Nighthawk R7000
Avast Mac Security reports my R7000 is vulnerable to hackers. It reports vulnerability ID CVE-2015-0932. I have tried to forward port 80 to an unused IP address and rebooted the router, but the probl...
- Nov 21, 2016
Hi All,
We have confirmed with Avast regarding the error and it's a false positive information.
Avast is looking into it to fix it on their side.
JohnMcEng
Oct 25, 2016Aspirant
I have the same problem. Really concerned and can't get an answer from Netgear
User input can be executed as a command
The device is vulnerable to hacker attacks. For more info see the corresponding vulnerability ID. An upgrade of the device's software/firmware may fix the issue
ElaineM
Oct 26, 2016NETGEAR Employee Retired
punsk Can you post a screenshot?
JohnMcEng Are you also using Mac and using the latest firmware?
Edit: Also, what's the exact version of your Avast and which Mac OS?
- punskNov 01, 2016Aspirant
Here is a screenshot. It's in Norwegian, but translates to something like this:
"User data can be executed as a command.
The unit is vulnerable for hacker attacks. You can find more information with the vulnerability ID. Upgrading the unit's software or firmware may solve the problem. Find out more (link: https://help.avast.com/en/av_mac_free/11/hns/alert_vulnerable_router.html )
Vulnerability ID: CVE-2015-0932"
My Avast version is 11.18 (46914)
I use Mac OS 10.11.6.
- ElaineMNov 02, 2016NETGEAR Employee Retired
Let me forward this to our engineering team.
Will provide feedback as soon as I got an update.
