sportryder13
Mar 09, 2016Aspirant
Avast! reports my Netgear Nighthawk X4 R7500v2 "is vulnerable to network attacks". V1.0.2.2
Purchased Subject router Netgear Nighthawk X4 R7500v2. Immediately updated old firmware to V1.0.2.2 prior to going forward with the rest on the configuration. Running Windows 10 Pro on my desktop. ...
- Mar 10, 2016
Hi sportryder13 Our engineers are currently working on this and will provide an updated firmware.
As of this writing, we do not have any ETA but this will be fix on the next firmware release.
ElaineM
Mar 10, 2016NETGEAR Employee Retired
sportryder13
Mar 11, 2016Aspirant
Update: New Beta firmware provided to me by the Netgear engineers. Loaded it up and all is well now. No network security vulnerabilities are reported by the router when queried by the Avast! Premier network security scanner tool. Firmware version is V1.0.2.4.
Instructions were straightforward. Very simple to accomplish. There were some tasks described in the instructions that were not necessary but I fully understand why they asked me to do that. After loading the firmware I was asked to reset the router to the factory default settings then reconfigure the router as if doing it from scratch. All is well in my network world now.
Kudos to the Netgear engineers, support reps and technicians. I appreciate your products, expertise and very timely responses to my problem although it was a false vulnerability reading which I had verified in my logs on the router and my firewalls.
Kind Regards,
