mynameisrobo
Jun 08, 2021Initiate
Avast Securty 14.9 is giving a vulnerability warning
Firmware on my R7000 is V1.0.9.88_10.2.88. When I try to upgrade, it says that I am current. No real details from Avast on the vulnerabilty. Here is a screen capture.
Portwey84
Jun 09, 2021Virtuoso
mynameisrobo wrote:Firmware on my R7000 is V1.0.9.88_10.2.88. When I try to upgrade, it says that I am current.
You're 5 firmware updates behind the most current one:
https://kb.netgear.com/000063684/R7000-Firmware-Version-1-0-11-123-Hot-Fix
Auto router update doesn't work on this router, well it has never worked on mine AC1900 model, so just disable it.
As for firmware updates, I recommend you do a manual check at least once a month because that's the only way you'll find out if you're on the most up to date firmware.
