Megarock
Mar 26, 2018Tutor
Avast Vulnerability Catalogue ID CVE-2017-14491 for the Nighthawk R7000 ac1900 dualband wifi router
I have got this report from Avast and Bitdefender after scanning my network and i have the latest firmware for my router. Any ideas if Netgear is working on a firmware update f...
- Aug 13, 2018
For the subject CVE-2017-14491 plus a few more items to address should be 2.78 or higher. Check http://www.thekelleys.org.uk/dnsmasq/CHANGELOG
Squair
May 24, 2018Guide
Hi,
Also having the DNS issue - port 53 - CVE-2017-14491 Vulnerablity. I did the nslookup and found my dnsmasq at 2.75. Avast says I'm in danger.
Thanks
- schumakuMay 24, 2018Guru - Experienced User
Squair wrote:
Hi,
R6900P?
Firmware version?If there is a 2.75 in place it's not updated, and Avast is right ...
dnsmasq starting from 2.78 is not vulnerable to CVE-2017-14491. Only CVE-2017-15107 (plus some other security enhancements) apply and are fixed in 2.79 FMI: http://www.thekelleys.org.uk/dnsmasq/CHANGELOG
ChristineT please - all firmware require an update to dnsmasq 2.79 (or newer) - the current 2.78 is no longer sufficient. And the default config should remove the non-documented and unsupported config option to query all DNS, too. Why does that all take that long?
- SquairMay 30, 2018Guide
My FW is v1.3.1.26_10.1.3 (no update available)
App= NIGHTHAWK 2.1.3.325
Why the Avast error? We are hearing the FBI tell us to reset our routers!
Have a good day. Thanks.
- schumakuMay 31, 2018Guru - Experienced User
Squair wrote:
My FW is v1.3.1.26_10.1.3 (no update available) Why the Avast error?
Because Avast does report a potential vulnerability/vulnerabilities which exist in the dnsmasq code on this old firmware. Because of Netgear was (and is to some extent) still lazy updating components in time and taking much more time to release firmware for all Netgear models.
Well, here we have even less information from Netgear. The information from Netgear available is very vague. Can't tell you more but that other vendors which were notified have updated their code in time early June 2017 already (and have supplied removal processes for effectively affected devices).
No idea on how long this will take for your router model.PaddyO wrote:
Mine is 2.62 how do i upgrade?
R8000 - there is a firmware update available for a few days R8000 Firmware Version 1.0.4.18 - check the R8000 Support Downloads for later updates.
