Rogarc1
Sep 13, 2021Aspirant
Avb network
Hi, I need tips for avb network vía WiFi, is possible? Regards
michaelkenward
Sep 14, 2021Guru - Experienced User
Not much to go on there.
What's AVB? Audio Video Bridging?
Are you trying to connect a particular device to your R8000 network?
Rogarc1
Sep 14, 2021Aspirant
Yes, I have Presonus mixer with AVB network (CS18ai and RM32AI)
- michaelkenwardSep 14, 2021Guru - Experienced User
Rogarc1 wrote:
Yes, I have Presonus mixer with AVB network (CS18ai and RM32AI)They will know more than anyone here about the configuration you need to connect the thing to the wifi. All routers will be in the same boat.
Find out from them what you need to do, and check the manuals for the R8000 about how to achieve this.
Or consult people here about the fine details.
