poulet750
Nov 11, 2021Aspirant
ax 1800 mk 62
Bonjour, j'ai acheter un router MR60 — Routeur Wifi 6 Mesh et quand je me connect dessus je n'ai pas d'internet. J'ai connecter et même reset le router en cliquant dessus 15sec. puis débranché...
michaelkenward
Nov 12, 2021Guru - Experienced User
As plemans says, we need more information.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
Then there is here:
Français - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
