ParryRiposte
Aug 09, 2021Follower
AX1800 and AC750 subnetting
I have an environment where there are WiFi dead spots due to the location/achictecture. I am looking to purchase both an AX1800 and Ac750, but would like to cofirm a few assumptions regading their c...
Aug 10, 2021Guru - Experienced User
AC1800 and AC750 are speeds. Not models.
What actual routers or devices are you looking at?
by the time you buy 2x routers, you might have looked at investing in a mesh system that would do those.
the SXK30 is a mesh systems and allows 4x ssids with different vlans.
That'd accomplish what you're trying to do and it'd function with seamless roaming and the ability to add more sateliltes for additional coverage if needed.
