larrygaia's avatar
larrygaia
AX1800 internet speed in nighthawk app
so is the internet speed that shows up in the nighthawk after running  speedtest  still that of the router plugged into the modem or of the  wifi speed at the closest  sattelite.  Numbers look too good at teh sattelite so wondering how to get the true speed  of the remote wifi signal.
1 Reply
  • plemans's avatar
    when you speedtest using the nighthawk app, it hosts the test off the router.
    To test satellites, you have to have a phone/pc connected to the satellite and test using the actual speedtest app.
    With mesh systems, you don't pick if you're connected to the 2.4ghz or 5ghz so you'll get a difference in speed (2.4ghz is a slow network)
    what actual system do you have? AX1800 is a speed.
