tbm-63
May 22, 2021Follower
AX1800 rename
For some reason my router and AX1800 Ext have the same name in my network settings. Is there anyway i can edit and change the name to ID it ?
May 22, 2021Guru - Experienced User
what router do you have?
what extender? (hint ax1800 is a speed)
Are you using the one wifi feature? (mesh)
