johntim14
Sep 03, 2021Aspirant
AX6 RAX 45 Wifi speeds less than half of ethernet
On my RAX45 AX4300 I am only getting about 180 Mbps when I test wirelessly through speedtest on my computer. When I hardwire connect it to one of the ethernet ports on the back, I get ...
Sep 03, 2021Guru - Experienced User
Many things impact wireless speeds. the router isn't usually the bottleneck. especially if you're getting 450mbps wired.
What actual wireless card is in the computer?
- johntim14Sep 03, 2021Aspirant
I believe the wireless card is integrated into my ASRock Z490 motherboard and is labeled as Intel(R) Wi-Fi 6 AX200 160MHz in my device manager. I get similar speeds when I test wirelessly with my phone as well leading me to believe that there is something wrong with the wireless signal being put out by the router.
- plemansSep 03, 2021Guru - Experienced User
What modem/gateway do you have?
What link speed do you show between the AX200 and the router?
are you connecting to the 2.4ghz or the 5ghz? 5ghz is much faster but doesn't broadcast as far or through as much materials.
My modem is a Motorola TM1602A MTA.
I believe I am getting 450 Mbps between the modem and the router as that is what is being indicated by the Nighthawk app and that is what I can get if I am connected via ethernet to the router.
I am connected to 5 ghz.
