jgohn
May 04, 2016Follower
back to my mac
Nighthawk X6 R8000 Firmware Version V1.0.3.4_1.1.2, OS X EL Capitan 10.11.4, "Back to my Mac" does not work?
- Sep 06, 2016
Hello JamesGL,
I installed the latest firmware yesterday and it seems to work without the DMZ. Thank you for the heads-up. This makes me love my router even more! ;)
GekkeHond
Jun 02, 2016Aspirant
I have the same problem. So I can help with the screenshots.
This should work through icloud so I don't have te set up/remember ip adresses etc. My previous router did work (a D-Link N router). So it is not something that only works with an Apple router.
Here is the Apple page about "Back to My Mac": Set up and use Back to My Mac
And here are the screenshots:
Details:
(it isn't slow, it just doesn't work).
The end result is I cannot reach my mac outside of my own network. It seems the UPnP does not work the way my iMac expects it to work (yes, I have UPnP turned on).
JamesGL
Jun 14, 2016NETGEAR Employee Retired
Hi GekkeHond,
We’d greatly appreciate hearing your feedback letting us know if the information we’ve provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
