jgohn
May 04, 2016Follower
back to my mac
Nighthawk X6 R8000 Firmware Version V1.0.3.4_1.1.2, OS X EL Capitan 10.11.4, "Back to my Mac" does not work?
- Sep 06, 2016
Hello JamesGL,
I installed the latest firmware yesterday and it seems to work without the DMZ. Thank you for the heads-up. This makes me love my router even more! ;)
JamesGL
Jul 19, 2016NETGEAR Employee Retired
Hi GekkeHond,
Try opening a port for your MAC. Check which port you need to open for "Back to my MAC".
GekkeHond
Jul 20, 2016Aspirant
"Back to My Mac" doesn't use a static port.
What I understood is that it uses my iCloud account on both devices to communicatie what port will be used on the moment I initiate the remote session, which can be anywhere between port 49152 to 65535. If I try to forward that range in the router I get an error it is already in use (which is true, there are UPnP portmaps active in that range).
I guess that is why it needs UPnP to make sure the right port is forwarded at the moment it is needed.
ps. Firmware Version V1.0.5.70_1.1.91
link about ports used my OS X: https://support.apple.com/en-us/HT202944
- JamesGLJul 25, 2016NETGEAR Employee Retired
Hi GekkeHond,
When it works with DMZ, which means all ports are open for that specific unit. The port that it uses may not be under the ports for UPnP. Can you verify with Apple if they have specific port to use. Can you try to load as well the previous firmware of the router and check if the same result.
- GekkeHondJul 28, 2016Aspirant
I don't have to verify the ports with Apple, because they have it on their site.
It's in the link I posted in my last reply: https://support.apple.com/en-us/HT202944
When you said
The port that it uses may not be under the ports for UPnP.Did you mean ports triggered through UPnP have a specific possible range? I do not know and/or can not find, what ports are available for UPnP. Do you have a list of port(range)s for UPnP on my router?
Or did you mean that my Mac tries to trigger a port for Back to My Mac already in use by anothet device on my network?
- JamesGLAug 31, 2016NETGEAR Employee Retired
Hi GekkeHond,
Have you tried the latest firmware of the router?
http://kb.netgear.com/app/answers/detail/a_id/30955?cid=wmt_netgear_organic
JamesGL
Community Team
