NetworkGuy36's avatar
NetworkGuy36
Backup Existing Firmware
How can I back the existing firmware on my router before upgrading?   Thanks, John
  • antinode's avatar
    Aug 02, 2017
       I wouldn't rule out the possibility, but I've not seen a way to do
    it.  (Saving the settings can be done, of course.)
       I'd download the old-version firmware kit (if you don't already have
    it) before doing the upgrade.  I also tend to do upgrades manually,
    because then I know where I've put the kit which I'm downloading.
       At: http://www.netgear.com/support/product/R7000#download
    there's a "+ View Previous Versions" button-thing which leads to a
    pretty long list.
