philippis's avatar
philippis
BAD REQUEST when trying to safely remove USB device from R7500v2 using the latest firmware
I did not have this issue with the initial release firmware for my 2 R7500V2 routers.  After upgrade to the latest 1.0.2.4, I cannot safely remove my hard drives from the router, either single drive,...
  • philippis's avatar
    philippis
    Jun 13, 2016
    No, it's definately the firmware.
    I reset the device as suggested.  I then tested the drives and got the same BAD REQUEST where it could not remove the USB drive.  I then updated the firmware to my previous 1.0.0.28 and the USB drive worked again.
    I have 2 of these routers, one as a bridge and one as a main router.  The main router has 2 6TB WD drives, and my bridge has a 1TB WD and 1 4TB WD.  After downgrading on BOTH routers the USB drive removal worked.
    This router is the R7500v2 I got in December when it was released.  I'm really surprised to see R7800 was released a month later.
    I guess for now, I won't be upgrading firmwares.
