stu3791
Jan 06, 2022Aspirant
BASIC SET UP
I will keep this simple so where to you plug in the above router in your/my house. My house uk BT line comes in to socket then what? Because when i plug mine in i can get no internet? Yes phone li...
stu3791
From what i can work our i need a modem for some reason there isn't one built in which to my surprise no one says or on the box
I have a VDSL / DSl connection which by my guess is about 80% in UK and i'm not the only one with this problem
so basically bit of a waste of money
supposedly one of the best routers out and i need a £24 modem to make it work pretty **bleep** !
michaelkenward
Jan 07, 2022Guru - Experienced User
The "reason" is that you bought a router. This is not the same thing as a modem/router.
You can't expect boxes to say what they don't include.
Your ISP almost certainly explains what you need. It might even offer to sell you the hardware. Most do, albeit at a price.
