adkrealtor
Mar 12, 2017Aspirant
Being blocked from certain websites
Hi - i know this has been previously discussed but thread was closed becuase it was a few years ago. Hi - I'm actually going crazy with work - and can't access my website because it's blocked. I had ...
- Mar 15, 2017
My 20 year old neighbor/computer tech figured it out. The server that I hosted my website on, black listed my IP address because I had too many incorrect password attempts :) I didn't know that was even possible! It also black listed my phone, which used my home wifi /same IP address. We emailed the server and asked them to "white list" my server which they did within 10 minutes. I was ready to blame Vladimir Putin!
adkrealtor
i'm hoping the retired netgear master wizard Babylons will find this and help. I can't reach hism directly
ElaineM
Mar 15, 2017NETGEAR Employee Retired
adkrealtor What's the model number of your NETGEAR device?
Do you remember enabling "Block Site" or "Parental Control" feature on your device?
Can you post a screenshot of the message you're getting when visiting a site?
Did you try factory reset on the unit? Resetting will wipe out all the settings so you will have to reconfigure the router to get back the connection.
