slyronit's avatar
slyronit
Best CFW for R7000 with Hardware NAT
I have a Nighthawk R7000 and have recently started looking for custom firmwares for it, basically for different Vlans on the Lan. I tried Kong's WRT- My 1G internet link couldn't exceed 500Mbps, no...
  • netwrks's avatar
    Oct 23, 2016
    Check this link -  you can cool the R7000 with AC Infinity dual USB fans. Amazon carries them. All my R7000's have 2 of the small USB fans under the router. Works great.  Temps around 47C - 52C depending on ambient temperature.
