JesusSaves
Dec 26, 2024Aspirant
Best Current Router
Hello. I’m moving into a 1 bedroom apartment. I’ve never had my own router, and the complex is recommending the NETGEAR NightHawk Smart WiFi Router (R6700)-AC1750. I’m not even sure what I need to loo...
Dec 26, 2024Guru - Experienced User
The 6700 has 5Ghz support though it's older wifi tech and limited on speed and performanced.
Something to check out would be NGs RAX series of routers or maybe a RS series.
Might start here first:
https://www.netgear.com/home/wifi/routers/
Depending on home size as well, you may check into a MESH system if you want more multi source wifi coverage:
https://www.netgear.com/home/wifi/mesh/
Start by selecting the Filter options to help you narrow down something that fits your home and networking needs.
JesusSaves
Thanks. It’s a small 1 bedroom apartment. Maybe 500 sg ft. There are walls but just a few.
- FURRYe38Dec 26, 2024Guru - Experienced User
OK, Try something RAX, maybe a RAX50 or 80 series would work good for you.
