JesusSaves
Dec 26, 2024Aspirant
Best Current Router
Hello. I’m moving into a 1 bedroom apartment. I’ve never had my own router, and the complex is recommending the NETGEAR NightHawk Smart WiFi Router (R6700)-AC1750. I’m not even sure what I need to loo...
JesusSaves
Dec 27, 2024Aspirant
I appreciate this information. I’m trying to find out more information about what is the apartment’s source. I’m assuming it something like if not xmission. I do have an iPhone 16 and fairly new Mac books so I want to make sure these will run optimally on the WiFi from my router.
JWS9518
Jan 02, 2025Luminary
If the internet service/modem is not great, even the best router will not help. I agree with FURRYe38 though, the RAX's are good and in a small place you don't want to oversaturate your wi-fi signal with a setup that overwhelms the signal.
- JWS9518Jan 02, 2025Luminary
One thing I would suggest though is future proof your setup by getting a router with some of the newer protocols such as 6E. May be a bit more expensive up front, but newer devices will be able to utilize to full effect and any future devices you buy will not be hindered by an outdated router.
- JesusSavesJan 02, 2025AspirantHey all. I appreciate your help. I did purchase a router. I hope it will work it is not a NETGEAR! It is TP-Link AX3000 WiFi 6 Router – 802.11ax Wireless Router, Gigabit, Dual Band Internet Router, VPN Router, OneMesh Compatible (Archer AX55)
- FURRYe38Jan 02, 2025Guru - Experienced User
Just FYI, that Mfr seems to be under scrutiny for nefarious things they seem to be doing.
Good luck with that.
