Fawnski
Aug 31, 2021Aspirant
Best firmware for R7000p in 2021
i have been having some weird issues with the R7000p, after a couple of months it would radomly drop connection and dissconnect my streams, even if i had it set up at a access point it would even cau...
Aug 31, 2021Guru - Experienced User
The version I usually recommend if users are having issues is the 1.3.0.20 version. Its the version prior to netgear armor.
But if yours worked fine with armor then I'd recommend the 1.3.2.124 version.
I'd also recommend factory resetting and reinstalling when changing firmwares on that router.
Fawnski
gotcha i never used netgear armor but i also bought the router after both those patches were released so ill try them both and see
