leilamuthu
Aug 11, 2020Star
Best firmware for R7000P?
What is the best firmware version for R7000P? After about 1 year of using my R7000P Nighthawk with no issues, all of a sudden 5Ghz decides to drop out 5-7 times a day. The logs show nothing of in...
- Aug 20, 2020
Currently stuck using v1.3.0.20.
I've also had to switch some critcal devices to the 2.5GhZ network as I can't risk those devices continually dropped off on the 5GhZ network.
A real shame that this Netgear product has been a waste of hundreds of dollars :(
Aug 12, 2020Guru - Experienced User
The ".42" version is for the R7000. Which is a different router from the R7000P.
The R7000P did get the netgear armor update.
A couple things you can try.
1. Rinstall the 1.3.2.124 firmware over an ethernet connection, factory reset the router after the reinstall/reboot, and then manually re-install the device (not from backup).
if it still has the issue, then:
2. Install version 1.3.0.20. This is the version prior to netgear armor. Not all devices played nice with Armor. maybe yours is one. Again, install over a hardwired connection, reset back to factory afterwards, and then manually reinstall it.
leilamuthu
Aug 12, 2020Star
Okay, the router is now on v1.3.0.20.
After flashing with this firmware, I did a factory reset and configured it all manually.
Fingers crossed!
Now we wait....if there's been no further dropouts in another 24-48 hours, I'll happily accept your solution!
I feel sick in my stomach that I can't rely on Netgear hardware though :(
- leilamuthuAug 13, 2020Star
Sadly, no luck with firmware V1.3.0.20_10.1.1 :(
After only about 2.5 hours, the 5ghz wifi dropped out again.
The only thing in the logs at the time (not the real MAC addresses):
[Admin login] from source 192.168.1.3, Thursday, Aug 13,2020 16:58:32 [DHCP IP: (192.168.1.4)] to MAC address xx:xx:xx:xx:xx:xx, Thursday, Aug 13,2020 16:42:44 [DHCP IP: (192.168.1.3)] to MAC address xx:xx:xx:xx:xx:xx, Thursday, Aug 13,2020 16:42:25 [DHCP IP: (192.168.1.4)] to MAC address xx:xx:xx:xx:xx:xx, Thursday, Aug 13,2020 16:40:06 [DHCP IP: (192.168.1.3)] to MAC address xx:xx:xx:xx:xx:xx, Thursday, Aug 13,2020 16:39:39 [Admin login] from source 192.168.1.3, Thursday, Aug 13,2020 14:03:27
Do I continue to work my way backwards in firmware versions to pre-V1.3.0.20_10.1.1?
- plemansAug 13, 2020Guru - Experienced User
You could try a 3rd party firmware like ddwrt. but if the 5ghz is dropping on the .20 firmware and the newest, it might be a hardware failure. But worth trying
Thank you. I'm hesitant to go the ddwrt/openwrt route in case it causes even more complexity.
I'll keep it as a last resource.
Next, I might try flashing with even earlier firmware, all the way down to v1.0.0.44...
And then, I will try activating the warranty process on the grounds of hardware failure, which I am still covered for.
Thank you for your help so far!
