leilamuthu
Aug 11, 2020Star
Best firmware for R7000P?
What is the best firmware version for R7000P? After about 1 year of using my R7000P Nighthawk with no issues, all of a sudden 5Ghz decides to drop out 5-7 times a day. The logs show nothing of in...
- Aug 20, 2020
Currently stuck using v1.3.0.20.
I've also had to switch some critcal devices to the 2.5GhZ network as I can't risk those devices continually dropped off on the 5GhZ network.
A real shame that this Netgear product has been a waste of hundreds of dollars :(
leilamuthu
Aug 13, 2020Star
Thank you. I'm hesitant to go the ddwrt/openwrt route in case it causes even more complexity.
I'll keep it as a last resource.
Next, I might try flashing with even earlier firmware, all the way down to v1.0.0.44...
And then, I will try activating the warranty process on the grounds of hardware failure, which I am still covered for.
Thank you for your help so far!
leilamuthu
Aug 20, 2020Star
- hh736Sep 02, 2020Star
Hi leilamuthu,
Turn off the Smart Connect feature of the router. I have the same router and it works for me. My FW version is: V 1.3.1.64_10.1.36
Thanks.
- leilamuthuSep 03, 2020Star
Thank you hh736 for your suggestion.
However I can confirm that the Smart Connect feature is turned off; I've never used it.
- Retired_MemberSep 29, 2020
I'm glad I checked here first - was thinking of switching back to try the new firmware (v1.3.2.124).
Yet in this case maybe I can offer some hope. I had the same issues on 1.3.1.64 with 5ghz dropping randomly and can confirm issue has not occured even once since I moved to use DD-WRT firmware.
So it seems to confirm a software issue and not the hardware. It was easy enough to do. Happy to talk more directly if something you may consider...
- hh736Oct 04, 2020Star
I've tried to switch back to v1.3.0.20 on my R7000P, but the extenders dont work for some reason - they just extend the -2G and -5G, but no internet connection...So, I updated the router with the latest firmware (from Netgear downloads site), and everything works good for now.
I'll update my review after a couple weeks.
- hh736Oct 10, 2020Star
Update: I did not have any drops since updating the FW last weekend - this is a good thing.
I'll update my review next weekend.
Thanks.
- hh736Oct 17, 2020Star
hh736 wrote:Update: I did not have any drops since updating the FW last weekend - this is a good thing.
Thanks.
Second Update: No drops since updating the FW on 10/3/20. Hopefully stays this way...I do recomend this version:
https://kb.netgear.com/000062114/R7000P-Firmware-Version-1-3-2-124
- BoggsbsOct 15, 2020Initiate
