leilamuthu
Aug 11, 2020Star
Best firmware for R7000P?
What is the best firmware version for R7000P? After about 1 year of using my R7000P Nighthawk with no issues, all of a sudden 5Ghz decides to drop out 5-7 times a day. The logs show nothing of in...
- Aug 20, 2020
Currently stuck using v1.3.0.20.
I've also had to switch some critcal devices to the 2.5GhZ network as I can't risk those devices continually dropped off on the 5GhZ network.
A real shame that this Netgear product has been a waste of hundreds of dollars :(
leilamuthu
Oct 06, 2020Star
Hi plemans
Yes, I did the following each time:
- Clean Install of Latest/Earlier Firmware with factory reset before and after (reset-flash-reset-reconfigure)
- Power Cycle
- Factory Reset
- Manually Reconfigure
Thanks.
Oct 07, 2020Guru - Experienced User
Have you tried turning the power output down on the 5ghz radio?
- timdugan19Oct 07, 2020Tutor
I have not tried that. Mine is set to 100%. What will turning this down do and any downsides to it? Thank you.
- plemansOct 07, 2020Guru - Experienced User
Never know. If you've tried everything that leilamuthu (the OP) has then its an option. Maybe the 5ghz is overheating/going bad. Running it at 75% power might let it run longer. It might cause some reduced distances/speeds.
- hh736Oct 07, 2020Star
You can use the free home version of Acrylic WIFI to see yours and your neighbors WIFI networks, and then pick up a channel, which has the lowest traffic and best signal:
For example - as you see from the picture all my networks on 2.4GHz are on channel 8, because my neigborrs and Xfinity are using 1, 6 and 11.
hh736 wrote:You can use the free home version of Acrylic WIFI to see yours and your neighbors WIFI networks, and then pick up a channel, which has the lowest traffic and best signal:
Not sure what happened to the snippet - I'll try again.
- leilamuthuOct 07, 2020Star
plemans Great idea, thank you. Have just dropped the power on the 5GhZ down to 75% and will see how it goes - fingers crossed.
Thanks hh736 I can confirm I have previously done this.
However, I downloaded Acryclic app as you suggested and can confirm that for my 5GhZ network, I am using channel 153 - the only other channel in use on this entire frequency near me is channel 100.
- wcalifasOct 08, 2020Prodigy
The R7000 is not known to have great firmware. I'd recommend manually installing version 1.0.9.42 firmware to the router, factory resetting it, and re-installing the router. And then disable auto-updates. This is the most stable version that we've found on these forums.
- antinodeOct 08, 2020Guru
> Re: Best firmware for R7000P?
> The R7000 is not known [...]
What's wrong with this picture?
> [...] I'd recommend manually installing version 1.0.9.42 firmware to
> the router, [...]I'd recommend against installing R7000 firmware in an R7000P.
- leilamuthuOct 08, 2020Star
Thanks wcalifas but this thread is about the R7000P, not the R7000.
THanks antinode !
Wow, really?! I've never read or heard anything about this anywhere - you can really MIX firmware from one device to another???
> you can really MIX firmware from one device to another???Generally, no. That's the principal reason for my recommendation.
- minsikauNov 06, 2020Aspirant
HI,
short story- Daughter needed a modem router and had a router only, so we swapped. (good DAD) My bad as it was very unreliable and poor in operation in so many ways. I ended up with the R7000p FTTP and she ended up with the TP VR600 on FTTN.
I changed to DD-WRT beta 44715 release and happiniess is once more in this house.
end of short story :)
Yes I had tried different FW versions, factory reset, examined all settings etc. As a electronics technician over nearly 40+ years doing ALL electronics devices to tag strip, and SM component level with a hobby of computing, ranging from CPM, dos, windows 1 , linux, unix and lots of propietry software in devices with snmp, web servers, GPIO control, yada, yada. I DO feel qualified to condem bad software and reward good software.
my 2 cents worth.
- AnonymousNov 07, 2020Agreed. I'm currently running DD-WRT v44406 and it's been 100% stable since I went DD-WRT.
That latest Netgear firmware didn't fix the random WiFi drops or explain why the Web UI admin pages would stop loading until restarted. Router hardware seems fine yet the official software is awful.
So avoiding Netgear for my next router upgrade. - hh736Nov 07, 2020StarThanks for your advice!
