Bw19630
Aug 16, 2021Follower
Best mesh add on for netgear R6350 router
I want to add to or three mesh devices to my existing Netgear R6350 router. Which mesh devices have installed and working with this router? No I can not replace router as my unique OTA WiFi supplied t...
Aug 16, 2021Guru - Experienced User
I don't recommend using more than 1 extender without switching to a full mesh system like Orbi or the MK nighthawk series.
Extenders are great at what they do but if you're needing 2-3 of them, its better to have a mesh system with something controlling it.
You can add a mesh system like orbi/MK to your R6350 and run the mesh system in access point.
michaelkenward
Aug 17, 2021Guru - Experienced User
plemans wrote:You can add a mesh system like orbi/MK to your R6350 and run the mesh system in access point.
I have an Orbi Mesh system sitting in AP mode behind an R7800 router. Works fine.
I don't even have to turn off the wifi from the R7800, but it can help to reduce wifi congestion and confusion.
