DickyC3PO
Oct 19, 2019Aspirant
Best optimal coverage setup using R6700 with existing AT&T Arris 5268AC fiber gateway
Hello Everyone, This is my first post, so please forgive me if I do any protocol mangling - it is not intentional. My wife & I have had AT&T fiber service for several months now, & have been less...
- Oct 20, 2019
DickyC3PO wrote:
We were given the standard Arris 5268AC telephony modem as the "heart" of our system.
To add to what plemans says, that is a modem/router. Which immediately lands you in worrisome territory.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. There may be ways to get the modem/router to cooperate, but sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportIn your case, the telephony bit is important. You don't want to discover that putting the modem/router into bridge mode kills the phone.
As plemans suggests, separating the modem/router and router could help you to spread the wifi. An alternative to running an Ethernet cable all over the place – doesn't always go down well with the family – is to use Powerline Ethernet to connect the R6700 to the fiber gateway.
Put the R6700 a bit nearer to the remote cameras and you might see an improvement.
michaelkenward
Oct 20, 2019Guru - Experienced User
DickyC3PO
Nov 05, 2019Aspirant
Micheal,
I'm with you relative to buying trouble using two routers in tandem on separate channels - been there/done that. I ended up disabiling my Arris gateway's wi-fi, & using the Netgear router as an AP. I also hardwired the output of the Netgear router to a TP-Link TL-PA7010 pwr line extender which is paired to a TL-WA855RE xmitter which is on one end of my home (closest to the most distant camera). I have a second TL-PA7010 that gives me a direct ethernet connection to my computer, & is paired with a 2nd TL-WA855RE that supplies the distant camera on the opposite end of my home w/wi-fi. All of my cameras now show a minimum of 80% signal, and are far more stable. My 5GHz speeds are (per fast.com) in exccess of 180Mbps dwnld & 130Mbps upload (as checked w/my Fire10 2017 edition) - not bad at all. FYI, The folks at TP-Link support also recommended using the same channel & SSID for all extenders. I'm a happy camper !.
Thanks a Bunch !
