SituFangs
Jun 27, 2021Follower
Best router to replace Nighthawk R7000
It was working fine until this morning. My partner and I couldn’t get a connection even though our devices were connected to wifi. Then when I tried to reconnect us, it said the password was incorr...
Jun 28, 2021Guru - Experienced User
what actual modem/gateway are you using?
What firmware is on your R7000?
the R7000 (when its setup properly) has been a pretty solid router. It does have some firmware issues but we can usually get things going decently.
