MRM4
Sep 14, 2021Tutor
Best signal booster for C7000
I just picked up the Nighthawk C7000 modem/router for our home to take advantage of our 400mb service. It certainly does that on a hardwired connection. The wifi connections are getting around 80mb o...
Sep 14, 2021Guru - Experienced User
Something to post about over in the WiFi Extender forum:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
A EX7700 or EX8000 will work.
Be sure to visit the cable modem forum as well:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Good Luck.
