MRM4
Sep 14, 2021Tutor
Best signal booster for C7000
I just picked up the Nighthawk C7000 modem/router for our home to take advantage of our 400mb service. It certainly does that on a hardwired connection. The wifi connections are getting around 80mb o...
Sep 14, 2021Guru - Experienced User
Are you testing those speeds over 2.4ghz or 5gh?
2.4ghz is a much slower network than 5ghz. It also suffers from more interference
