JDLH
Jul 27, 2018Initiate
Best way to lessen bright LED lights?
The white LED status lights on the top of my AC1900 Nighthawk R6900P router are very bright. The device is in a guest room, and it is enough to make me worry it will disturb my guests' sleep. Is ther...
- Jul 27, 2018
microchip8 wrote:
Turning them off might be another solution.
The manual explains how to do this:
>>> R6900 | Product | Support | NETGEAR <<<
See the section Disable LED Blinking or Turn Off LEDs.
microchip8
Jul 27, 2018Master
you can't control the brighness, only whether they are on or off. Turning them off might be another solution. But if you need to see the status, covering them up with some tape that lets less light through is the only other solution
- michaelkenwardJul 27, 2018Guru - Experienced User
