JDLH
Jul 27, 2018Initiate
Best way to lessen bright LED lights?
The white LED status lights on the top of my AC1900 Nighthawk R6900P router are very bright. The device is in a guest room, and it is enough to make me worry it will disturb my guests' sleep. Is ther...
- Jul 27, 2018
microchip8 wrote:
Turning them off might be another solution.
The manual explains how to do this:
>>> R6900 | Product | Support | NETGEAR <<<
See the section Disable LED Blinking or Turn Off LEDs.
antinode
Jul 27, 2018Guru
> [...] putting a piece of cardboard or something over the top of the
> lights, [...]
That may be the best practical way. I use (modern) paint-masking
tape (with a long-life adhesive), sometimes multiple layers.
Be careful when covering combined LEDs and button-switches.
