Larry75
Sep 03, 2022Aspirant
best wifi encryption?
Hello everyone. What is the strongest encryption for WiFi and why? Please site a source for your statement. Thank you. WPA2-PSK (AES) WPA-PSK (TKIP) + WPA2-PSK (AES) WPA/WPA2 Enterprise WPA...
michaelkenward
Sep 04, 2022Guru - Experienced User
What is the strongest encryption for WiFi and why - Google Search
What is the strongest encryption for WiFi and why - Search (bing.com)
Larry75
Sep 04, 2022Aspirant
I already looked it up. No clear answer.
My guess, strongest probably is
WPA2-PSK(AES) + WPA3-Personal
Am I right?
- plemansSep 04, 2022Guru - Experienced User
both have vulnerabilities currently. I'd say wpa3 is more secure as there's more tools for cracking wpa2 password currently so the general masses know more about them but there's tools for both.
But more importantly is just choosing a smart password for your network.
Many times its simple guesses that get people access to networks or even not having a password at all.
Its just like at a home, you can't make it fully 100% safe from robbers but you can do your best to dissuade the general public and make it hard enough that it isn't worth their time.
- schumakuSep 04, 2022Guru - Experienced User
The only reason to operate mixed mode like WPA2-PSK(AES) + WPA3-Personal would be to continue clients not capable for operating WPA3-Personal clients, or having interoperability issues limitations.
- Larry75Sep 04, 2022Aspirant
Thanks for your reply's.I already use a large password, over 40 characters.
Security researchers recommend WPA2-PSK (AES) with a long password. WPA3-Personal does not seem to be recommended.Does using WPA2-PSK(AES) + WPA3-Personal provide stronger encryption compared to just using WPA2-PSK(AES)?
Say a person was close to my router (outside a building) snooping my WiFi signals in transit to it's final destination, they would only be getting encrypted data. Question is, does using two protocols make it stronger than using one?
