Larry75
Sep 03, 2022Aspirant
best wifi encryption?
Hello everyone. What is the strongest encryption for WiFi and why? Please site a source for your statement. Thank you. WPA2-PSK (AES) WPA-PSK (TKIP) + WPA2-PSK (AES) WPA/WPA2 Enterprise WPA...
Larry75
Sep 04, 2022Aspirant
Thanks for your reply's.
I already use a large password, over 40 characters.
Security researchers recommend WPA2-PSK (AES) with a long password. WPA3-Personal does not seem to be recommended.
Does using WPA2-PSK(AES) + WPA3-Personal provide stronger encryption compared to just using WPA2-PSK(AES)?
Say a person was close to my router (outside a building) snooping my WiFi signals in transit to it's final destination, they would only be getting encrypted data. Question is, does using two protocols make it stronger than using one?
schumaku
Sep 05, 2022Guru - Experienced User
Get some more readings and study - WPA3-Personal is lightyears ahead, look into Simultaneous Authentication of Equals (SAE) method.
Even the Opportunistic Wireless Encryption (OWE, Enhanced Open) - without the need for knowing a password (where no access restrictions need to be applied) - does provide the same protection like WPA3 over the air.
Nope, the "+" notation isn't a mathematic "feature additions". This is to allow WPA2-Personal clients to operate along the WPA3-Personal clients.
- Larry75Sep 05, 2022Aspirant
Thanks for your reply.
Basically, you are telling the best wifi security option is WPA3-Personal with a really long password?
You also say
WPA2-PSK(AES) + WPA3-Personal (in that configuration) is designed for compatibility, not for enhanced security? Do you have source on that statement, I wish to further read upon it.
Thanks.
- michaelkenwardSep 05, 2022Guru - Experienced User
Do you have any particular reason for being worried about wifi security?
If so you might like to think about some of the belt and braces options that people like Netgear are happy to sell to the terminally paranoid.
