Larry75
Sep 03, 2022Aspirant
best wifi encryption?
Hello everyone. What is the strongest encryption for WiFi and why? Please site a source for your statement. Thank you. WPA2-PSK (AES) WPA-PSK (TKIP) + WPA2-PSK (AES) WPA/WPA2 Enterprise WPA...
Larry75
Sep 05, 2022Aspirant
Thanks for your reply.
Basically, you are telling the best wifi security option is WPA3-Personal with a really long password?
You also say
WPA2-PSK(AES) + WPA3-Personal (in that configuration) is designed for compatibility, not for enhanced security? Do you have source on that statement, I wish to further read upon it.
Thanks.
michaelkenward
Sep 05, 2022Guru - Experienced User
Do you have any particular reason for being worried about wifi security?
If so you might like to think about some of the belt and braces options that people like Netgear are happy to sell to the terminally paranoid.
