obxpav's avatar
obxpav
Blicking amber after PC is shut down.
Hello!   After shutting down Windows 10 laptop, the ethernet port is active. (blinking amber LED) . Question. Who or what is the laptop still "talking to"? I can this chatter be controlled?   Tha...
  • obxpav's avatar
    obxpav
    Feb 09, 2020
    Solved just as antinode prescribed. Wake-on-LAN was turned off and the port LED indicated no traffic.
    My thanks to you as well EPAD for taking time to look at the question and offer options to consider.
    To answer your questions. 1. Yes, the computer is wired and that is how the amber port light was illuminated. Since there are no SYNC/AKN lights on this model laptop, the amber LED on the router #3 port..The port that the laptop is jacked into, let me ID the active device.
    Again,
    My thanks you and antinode for taking the time to look at the question and offer options to begin working on a solution! Well done. -Paul
